Match drilled the hinges and shims for the engine cowl to the firewall flange. Debured and dimpled the shims and debured and counter sunk the hinges. Primed the hinges with rattle can self-etching primer. (The shims were primed previously when I made them.)
Riveted the firewall flanges to the forward fuselage skins with the cowl hinges in place.
Ran 2 additional wires for solid grounding. A #10 AWG from the ground bolt attached to the fuselage at the rear left seat side forward to connect to the main ground bus. Plus a #14 AWG from the air conditioner blower forward to connect the the main ground bus at the panel.
