Smoothed the cover panels painted yesterday with red Scotch Brite pad. Applied anotherr coat of paint to these panels.
Used the HVLP spray gun with the 2.5mm nozzle. Diluted the paint 5:1 with water to thin it slightly. This helped and the paint sprayed properly. Left the paint to dry over night.
Sanded down the epoxy/micro applied to fill the 2 flaws in the cabin top. Applied 2 coats of UV Smooth Prime to the sanded areas using a trim pad paint applicator with slightly thinned primer left over from spraying the entire inside cabin top.
