Painted about 2/3 of the interior cover panels and inspection covers. Tried using a Harbor Freight HVLP spray gun with 1.4mm nozzle, but the paint was too thick to properly spray. Tried transfering the paint to the gun with 2.5mm nozzle purchased for spraying the UV Smooth Prime, which worked a little better, but still didn't spray well.
Left paint to dry.
Applied an epoxy/micro mixture to further fill the 2 small areas that had defects due to air entrainment in the original epoxy application.
