Dave's RV-10 Build Log
Date:  2-16-2017
Number of Hours:  8.00
Brief Description:  Plexiglass Trimming; Cabin Top Drilling
Finished trimming and fitting the main wind screen into the cabin top. Used a combination of Dremel tool with 1.5" metal cutting disks and a 5" random orbit palm sander with #60 sanding disks. Took multiple fittings to get the fit right, slowly trimming so as not to over cut the plexiglass. Taped a small wooden block to the top of the glare shield in the center with duct tape so that each time I placed the windscreen in place it was at the same location, and didn't slide/move while fitting.
Removed the cabin top and match drilled the rivet holes through the rear top flange into the aluminum backing strip, using cleco clamps to hold the strip in place and clecoes in every other hole and they were drilled from the center down to both sides.
