Removed clecos from overhead console and cleaned up the console mounting flanges of adhesive.
Determined routing of wires for the tail light using a J stiffener in the tail cone along the left side. Power wires will be run on the left side, and avionics signal wires and coax wire will be run along the right side.
Drilled the hole in the back bulkhead between 2 mounting holes for the vertical stabilizer as indicated in the OP-37 drawings. Had to drill a larger hole than indicated to accomodate the larger number of wires required for the AeroLEDs Suntail light. Drilled a matching hole in the vertical stabilizer mounting flange.
Measured wires for the tail light, tied them with lacing cord, and installed them into the tail cone.
