Dave's RV-10 Build Log
Date:  12-8-2016
Number of Hours:  3.50
Brief Description:  Parking Brake Valve
Installed a Parking Brake Valve into the brake system.
Un-clecoed the glare shield/control panel and removed it to allow easy access.
Drilled out 8 rivets and removed the brake header bracket
Built up the brake valve bracket and riveted it into the place previosly occupied by the header bracket.
Installed the actuation cable clamp to the valve lever and installed the valve into the bracket on the firewall.
Re-connected the brake lines to the valve and tightened all fittings. Torque painted the fittings.
Parking Brake Valve Installed
Firewall Side of Brake Mount
