Separated the parts of the F1099-E,F,G, & H with band saw and cleaned up the cuts with the Scotch Brite grinder wheel for both the left and right sides. Deburred all edges with either the grinder wheel or a hand file.
Separated the parts of the F1099-D Wing Root Fairing Stiffeners using the band saw. Then trimmed the top edge angles using tin snips. Cleaned up all cuts with the Scotch Brite grinder wheel, and deburred all remaining edges with a hand file. Dimpled the rivet holes using the DRDT.
Cut both VA-256 Flap Pushrods to length as shown on Page 44-5 using the band saw and cleaned up the cuts and finalized the lengths using the Scotch Brite grinding wheel. Installed the rod end bearings, setting the lengths as shown on the plans.
