Reduced the size of the edge flanges on the fiberglass cabin top in order to fit them within the door opening of the fuselage. Got it to go into the opening but the radiused outer flange was sticking out beyond the side skin.
Stopped early and went home to call Van's builders tech support to ask. Was told that this needs to be pulled inside the fuselage to be even with the outside edge in order for the doors to fit properly, and so I should sand them thinner. Was told that these sides are typically very thin within the fuselage door openings, and are not structural.
