Installed the new rod end into the Elevator push rod and set up the end berings per the drawings.
Marked the door opening area of the fuselage per the drawings.
Went over the scribed lines with a Sharpie on the fiberglass top to make the lines visible.
Cut the excess fiberglass from the rear bottom and the rear windows. Sanded down to the scribed lines. - Tried using a 3" cutoff disk first, but it didn't work very well. - Switched to the Dremel tool with a small diamond cutting distk. This work reasonable well for cutting the fiberglass prior to "sanding"
