Dave's RV-10 Build Log
Date:  9-12-2016
Number of Hours:  8.00
Brief Description:  Control System
Began work on the control systems.
Fabricated the Elevator Idler Arm. However, could not install it as the mounting bracket holes had not been drilled to 1/4" size. Ordered a compact pneumatic angle drill as the only way to enlarge the hole.
Match drilled the control stick bases and final drilled the control column and installed it.
The control stick base bushings were properly sized for the control stick bases, however the bases were too large to fit in the control column. So had to grind down the bases to fit, and then cut down the brass bushings to fit the shorter bases.
Installed the control sticks and push rods.
Set control sticks parallel with each other.
Fabricated the measuring jig.
