Brief Description: Anti-Yaw Bracket and Static Air Tubing
While in the tail cone, I started installation of the tubing to connect the static ports together and connect to the tubing run previously to the fromt panel area along the left side wall. Fabricated a small bracket out of scrap aluminum angle and attached it to the bulkhead with 2 rivets. Mounted the T provided with the SafeAire EFIS tubing system to that bracket. Cut and installed a small length of tubing between the left side static port and the T.
