Dave's RV-10 Build Log
Date:  10-15-2019
Number of Hours:  7.50
Brief Description:  Installed Roll Servo and Wings
Installed the GSA 28 roll servo into the right wing using the mounting brackets.previously installed prior to closing the wings. Checked ailerons for full range of motion and found they properly reach limiit stops prior to hitting the servo stop bracket.
Installed both wings onto the fuselage, using drift pins to locate the main spar holes and then hardware store 3/8" bolts (2 per wing) to secure the wings to the main spar.
Aligned and clamped the rear wing spar using the #40 pre-punched holes for alignment. Checked wings to ensure both were at the same angle of incidence using a 48" level as well as with the iPhone level app. Both methods show the alignment to be correct. Drilled the rear spar bolt hole using 3/16", 1/4", 5/16" and then a 3/8" (0.373") reamer. Bolted each wing's rear spar per the construction drawings.
Drilled and installed the F-1054 Tank Attach Angles.
Bolted the Aileron Pushrods to the torque Tubes.
