Brief Description: Smooth Wing Tip Insert with Epoxy-Micro
In order to smooth the wing tip nose at the point where the insert was epoxyed into the standard wing tip, I filled the area between the insert and the lens joggle.
Filled in the lens joggle with 20 mil PVC tape ordered through Home Depot Sanded to rough up the surface and cleaned with acetone Mixed up a batch of epoxy with slow hardener and micro-bubbles to a fairly thick/stiff consistency Applied the epoxy-micro mix to the area between the insert and PVC tape, smoothing it with an epoxy squeege.
Will sand smooth and blend in tomorrow after the epoxy has set.
