Brief Description: Install Inlet Seals, Seat Belts; RTV Baffle Sealin
Installed air seal fabric on the bottom cowl left and right air inlets per FF2-20.
Removed front seats. Consider moving nut plates from inside seat to outside of seat adjustment latch, and lifting the seat cushion to install/remove seats. As currently configured it is very difficult to install or remove the bolts, and will be impossible once the side covers are installed.
Glued rubber trim strips to center console using super glue gel.
Installed seat belts to bottom anchors and rear seat shoulder harness to cable running into tail cone.
Sealed engine baffles with red high temp RTV, including patches of air seal fabric on SCAT tubing to protect it from chafing.
