Brief Description: Re-installed Rudder Trim. Removed Van's Left Door
Re-installed the replacement rudder trim control box received from Aero Sport Products. This one is 3D printed rather than macihined aluminum.
Installed new wire with connectors onto power supply to fit EarthX connector installed at the battery downstream of the master relay. (Not using EarthX battery, just their charging/jump start cable.)
Removed Van's door seal from the left door as it is too fat and doesn't allow the doors to close. Also, the silicone sealant used doesn't hold the weather seal securely in place. Pulled the seal off of the door and started peeling the silicone off the door.
