Installed Air Conditioner condenser with scoop onto bottom of fuselage temporarily for weighing.
Pulled plane onto scales borrowed from EAA 302 tool crib with help of Henry Jetlina.
Weighed plane 3 times:
Weights with rear seat, without wheel or gear fairings: Nose: 338 lbs, Left Main: 681 lbs. Right Main: 675 lbs. Total: 1694 lbs
Weights with rear seats, with wheel and gear fairings: Nose: 341 lbs, Left Main: 684 lbs. Right Main: 678 lbs. Total: 1703 lbs
Weights with out rear seats, without wheel or gear fairings: Nose: 351 lbs, Left Main: 659 lbs. Right Main: 654 lbs. Total: 1664 lbs
Checked Van's typical W&B dimensions against my aircraft and found them to be correct within my ability to measure distances using a tape measure and plumb bob. Therefore will use Van's dimensions for W&B calculations.
