Brief Description: Rudder Trim, Door Seal, Preservative Oil Drain
Installed AeroSport rudder trim unit. However when attempted to adjust trim, the unit was binding badly. After talking to Will at AeroSport, removed the unit and opened it up.Found that the cables were in their proper position, but that the drive gear was moving back and forth and jamming the pully gear. Talked again to Will, and AeroSport will send a replacement unit (one of the new 3D printed units).
Removed clecos from right door seal. Found seal was secure except for an area between the 2 door hinges at the top. Cleaned that area, sanded again, cleaned with acetone, and re-glued with silicon.
Removed the bottom spark plugs and oil drain plug allowing the preservative oil to drain out. Left them out for the night with cloths/bucket under them to completely drain.
Prepared pilot's door for gluing weather seal by sanding edge and cleaning up the aluminum cleco clamping strips.
