Dave's RV-10 Build Log
Date:  9-20-2019
Number of Hours:  5.00
Brief Description:  Packing Shop for Move to Airport
Completed packing up the shop to complete the move to the airport.
Took down the overhead hoist. Will bring it home and sell it as it will not be useful in the hanger.
Will take the engine hoist to the hanger as I will need to re-install the main gear wheel pants brace (removed to fit on the truck), so will need to lift each side to remove the wheel nut. This will be easy with the engine hoist lifting the main wing strut using the lifting eye installed to raise the fuselage onto the work bench for gear installation.
Did not disassemble the shelving units. May take these on the moving truck, or disassemble them later and move in pieces in the car.
