Brief Description: Complete Brake & Alt Air Cables, Install Right Win
Finished up the installation of the parking brake and the alternate engine air door push-pull cables including installation of the left panel lower side piece.
Installed the F-105 engine mount bolt access plates in both front footwells.
Installed the fuselage side of a circular wiring connector unit including crimping pins and soldering shield drains which also are carried through the connector. (AMP Tucson Circular Package Cable Clamp product # 206070-8, which uses the same pins as a standard DB connector).
