Continued work installing elevator trim servo. Placed servo with bracket into tail cone and ran cables to trim tabs. Used car battery with jumper cables to activate servo and move it to end of range. Had to unscrew servo mounting bracket to gain enough length to re-adjust trim end of cable mounting to access plate in order to lengthen cable to allow the specified 35 deg. at full extension.
