Installed Halon fire extinguisher bracket to the front lower edge of the front right (copilot) seat support, below the stick. Used CS-4 rivets with #6 counter sink washers to attach the bracket. Installed the Halon extinguisher into the bracket.
Adjusted the left elevator trim tab so that it matches the right tab at the point of reversal. Re-installed the tab cable and tightened jan nut. Torque sealed the jam nut.
Cleaned the front windscreen using mineral spirits to remove adhesive left from the protecting plastic film. Followed with clean water and then Prist windshield cleaner.
