Reinstalled the tunnel covers. Reinstalled the center console. Checked fuel valve handle operation and found that while it would now fit, it wouldn't lift enought to disengage from the detent. Lengthened the slots in the fuel valve stem slightly using Dremel with small diamond cylindrical bit until the handle would lift enough to disengage from the detent plate. Installed the fuel selector handle and indicator plate. Installed the center console arm rest hinge and arm rest to the console. Installed the front headset jacks into the center console bucket.
