Dave's RV-10 Build Log
Date:  3-3-2020
Number of Hours:  4.00
Brief Description:  Fixed Brake Fluid Leak. Adjusted Right Aileron
Removed seat rails and floors to gain access to the brake line fittings. Had to remove 3 of the screws with "easy out" due to stripped heads. Tightened nuts on brake line fittings at bulkhead fitting next to gear legs and also at bulkhead fitting through the tunnel sides. Bled both brakes as the brake line on the right brake was showing air in the fluid line from the copilot master cylinder to the reservior. Tested brakes fro leaks by pressing hard on both peddles several times to pump the brakes and then held pressure for > 1 minute. No fluid evident at any of the fittings or on the lines now.
With the area open, adjusted the right aileron push rod at the copilot's stick so that both left and right aileraons are aligned with flaps at the 0 deg. position.
