Brief Description: Replaced Left Door Seal. Installed Wing Walk Tape
Finished removal of left door seal by removing the silicone sealant using a razor blade and 60 grit sandpaper. Cleaned up with acetone. Installed "MD Auto & Marine Rubber Weatherseal" onto the cabin opening edge for temporarily sealing the left door. (Will eventually convert door seals to the McMaster Carr seal system detailed on VAF).
Removed baggae bulkhead panels and engine cowl. (Needs to be removed for fuel flow testing and DAR inspection, and will allow Oren Rokach to better view A/C install when he visits on Friday from Israel.)
Installed skate board Grip Tape on both wing walk areas for safety. This will be removed by the paint shop at time of aircraft painting (following phase 1 testing).
