Dave's RV-10 Build Log
Date:  1-16-2020
Number of Hours:  6.75
Brief Description:  ELT Install, Cowl Support Bracket, Exhaust Pipes
Tested the ELT for activation with sudden de-accelleration per ELT instructions. Tested at 2 min. past the hour. Test confirmed ELT proper operation. Installed the ELT into the tail cone.
Entered log book information on the ELT, Engine, Mags, Alternators, TCW Backup Battery, SureStart, and brake fluid.
Painted the main battery hold down bolts as they were starting to rust a little.
Re-positioned the exhaust pipes to provide more space between them and the lower cowl, placing them about 3/4" below to fuselage bottom edge.
Attached the cowl support bracket F-10108A to the bottom edge of the fuselage. Installed the FAB and fuel pump overflow tubes to the bracket.
Re-installed the top wing root fairing for weighing the aircraft.
