Removed clecos from pilot's door. Cut openings in seals for door latch pins on both doors. Doors are now too tight, maikng it almost impossible to close and latch them. Closed and latched both doors, to hopefully allow the seals to compress with time and make door closeing acceptable.
Removed remaining blue plastic from the fuselage.
Installed the flaps onto the wings using the hardware called out in the drawings. Had to trim the inboard edges of both flaps to fit without rubbing when the flaps are fully retracted. Used a random orbit pad sander with 60 grit paper to remove most of the material, and did final clean up with a file. Checked full up that the flaps were at -3 deg.
Installed the flap push rods between the flaps and the flap actuator arms. Powered up the aircraft with the regulated supply and operated the flaps to confirm proper operation. Will need to reverse the travel directions in the G3X setup.
