Connected the pitot heater wires at the wing root using the wires run to the wing root from the panel, and the wires run inside the wing (installed prior to closing the wings). Used crimp butt splices to make the connections.
Connected the fuel level wiring to the level transmitters using ring terminals on the shielded twisted pair cables installed to the wing roots as part of the panel wiring.
Re-connected the fuel supply lines to the wing tanks at the wing roots. Re-connected the fuel tank vent lines to the tanks.
Installed the bottom wing root fairings. (Upper fairings left off for airworthyness inspections.
