Installed the GMU 11 into the right wing, just inboard of the wing tip, using the bracket installed on Aug. 7th.
Installed the Ray Allen G407F stick grips on each stick. (Sticks were cut on 10/23). Used the 7/8" spacers provided, with 2 #6 set screws drilled and threaded into the grips to secure them to the sticks. Had to de-pin the grip that I used previously for testing, as the DB-9 connector won't fit through the stick. Added pins to the other grip, and then installed DB-9 connectors to each to match up the the connectors previously wired at the base of the stick. Laced the wires to each stick at several points. Tested the grips and found that there was a problem with the left stick aileron trim function preventing trim to the right.
