Dave's RV-10 Build Log
Date:  10-9-2019
Number of Hours:  7.00
Brief Description:  Wing Root Fairings, Fuel Strainers
Installed nutplates for wing root fairings, including those missed by the Van's Quick Build team.
Installed fuel strainers in wing tanks
Replaced tail light connectors that I had to remove in order to install the vertical stabilizer and thread the cable through the lower stabilizer attachment. Had to replace both halves of the connector as the 5 pin connector I used is discontinued, so had to replace with a 6 pin connector. Connectors purchased from Amazon were supposed to be Molex, but I doubt they were as fitting the pins into the connector shells was very difficult.
