Brief Description: Left Heat Inlet, G5 Install, Vent Fan Trim Rings
Riveted the left heat inlet nozzle to the left inlet ramp, with screen in place and using RTV to seal it. Also riveted the plate covering the original hole using RTV to seal it.
Installed the G5 bracket made earlier and painted black to the glare shield using black screws with washers and Nylok nuts. Installed the G5 to the bracket, inserting the pitot and static tubing into the G5 fittings. Attached the DB connector to the back of the G5.
Worked on installing the locking cams on the door locks. Determined that the cam needs to be bent up about a 1/8" to work right. Tried bending and cutting one of the flat cams but wasn't able to bend it close enough to the lock to work right. Will look for pre-bent cams to purchase that will work.
Glued the vent fan trim rings into the glare shield covering that I had 3D printed earlier. Used the same contact cement to glue them in place as used to secure the glare shield "leather" cover.
Sprayed the inside of the lower cowl with another coat of high temp whiite paint.
