Dave's RV-10 Build Log
Date:  8-21-2019
Number of Hours:  7.00
Brief Description:  Re-Installed Heater Controls Mount Sure Start
Re-installed both heater control cables through panel console side piece and to individual heat valves. This was difficult to accomplish with all of the engine hoses, wires, etc. in place.
Installed the SureStart ignition unit onto the front of the firewall. Taped a box end wrench to the inside of the firewall to hold the nut and then tightened the bolt from the engine side.
Determined approximate route for the alternate air intake cable from the panel to the filtered air box door.
