Brief Description: GMU Mount & Connectors for GMU and GSA 28
In reading the GMU 11 installaton instructions again, I realized that I couldn't just screw it to the wing spar at the end of the wing as the bottom of the GMU needs to face the ground. So I need a bracket to hold the GMU 11 at right angle to the spar.
Since I purchased a mounting bracket for the GMU 22 from Stein Air a couple years ago, before the GMU 11 was introduced, I decided to try using it to mount the GMU 11. By drilling new mounting holes that match the GMU 11, I can use it. Drilled 6 holes in the mounting base of the bracket, and then match hole drilled these through the right wing spar outboard of the gold anodized main spar. Fastened the bracket to the spar with 6 LP4-3 pulled rivets.
Built the connector for the GMU 11 with the wires installed yesterday.
Built the connector for the GSA 28 Roll servo using the wires run prior to installing the bottom skin of the wing.
Tested the CAN Bus wiring for shorts to ground, opens, or cross connections, and didn't find any.
Ordered the seat belt harnesses from Crow Enterprises (not included in the hours logged for today).
