Brief Description: Software Updates, Com Tests, Config Checks
Downloaded the software update files for the G3X and GTN 650. Ran the files downloaded to install the setup software to one SD Card for each system. Took the cards to the shop.
Installed the SD card in PFD-1 and allowed the software update to run and complete. Moved the card to MFD and allowed the software update to run. Moved the card to PFD-2 and again allowed it to run. All 3 GDUs are now at the latest software release.
Installed the GTN card in the GTN 650, and followed installation instructions to install the updated software in the GTN 650. Both the GTN 650 and G3X now need updated data files, which I will do closer to first flight since this will require a subscription.
Checked configuration for the G3X - GTX 45R communications and changed a couple that were incorrect. Also checked configuration for GTN 650 - G3X communications and changed a few that were not configured or incorrectly configured.
Tested the COM 1 and COM 2 radios, using an old headset plugged into the pilot jacks, the pilot stick grip transmit switch, and my hand held radio. Tested on 122.700 and all radios seem to transmit and receive correctly.
Started creating a list of everything still needing to be completed before moving to the airport, and a list of everything still needing to be done at the airport prior to airworthyness inspection
