Brief Description: Cut Right Avionics Tray, Removed heater cables, wi
Bundled wires on right side of panel with waxed lacing tape in place of temporary tie-wraps.
Cut left side panel of the right avionics tray to provide clearance for main wire bundle run across the sub-panel. This required re-mounting the GAD 27 LRU to allow the cut.
Removed the heater control cables and cut the cables to shorten them based on marks from a couple weeks ago. Cut the outer cable using a dremel tool with metal cut-off disk, then cut the inner cable with wire cutters so that 5" extends beyond the end of the outer cable with the knob fully in. Mounted the cable knob ends to the panel center right side with front heat on top and back seat heat on the bottom. Will need labels for these knobs.
Added missing wire for overhead light switch.
Glued the rear seat heater SCAT tube to the spot provided in the spar usiing RTV and clamping the tube with a clamp on each side holding a small board down on top of the tube.
