Dave's RV-10 Build Log
Date:  7-1-2019
Number of Hours:  8.00
Brief Description:  Coax Connections, Stick Grip Wires, Right Air Vent
Routed the RG-400 coax cables to each of the LRUs in the panel that were previously installed from the tail cone. Installed BNC and TNC connectors to these coax cables and connected the cables to the LRUs. (COM 1 to the GTR 20R, COM 2, NAV, and GA 45 GPS to the GTN 650, GA 57X GPS to PFD-1, and GA 57X XMS to MFD) Also replaced the BNC connector originally installed at the GA 45 antenna location with the proper TNC connector. Checked each coax for short between center conductor and shield with ohm meter (none found).
Determined additional wires required for the stick grip switches and installed these additional wires. Cut the tunnel cover at the indicated area near the fuel selector valve stem after drilling a 3/4" hole at this split point for installation of a snap bushing. This will allow the stick wires to be run above the tunnel cover/under the center console to near the stick grips and then through the tunnel cover at the split so the wires are kept reasonable length; not crushed at the end of the tunnel cover between the brake lines; and allow the tunnel covers to be more easily removed without having to remove/disconnect the throttle quadrant and associated push/pull cables.
Installed the right side panel air vent and SCAT tubing between vent and air inlet fitting.
