Brief Description: Primary Alternator, Solidnoid Diodes, Avionics Fan
Ran a #6 AWG wire from the central breaker panel to the right side breaker panel to connect the main bus between them. Installed crimp terminals which will be connected to the breaker bus after the panel is installed in the aircraft.
Completed wiring for the pilot's seat heaters. Have 3 spare wires under each front seat as they are not required after determining the heater wireing arrangement and revising the wiring to work better with the location of the switches and circuit breaker. Left them coild up.
Cut off the computer power connectors for the avionics fans and soldered the power wires in such a way that the fan speed reduction insert wires can be plugged in if desired. Wires are ready to connection to panel.
Installed wires through the firewall on the left to energize the starter solenoid from the start switch. Connected the start switch wire to the solenoid along with the ground wire and the diode to protect the switch from current spikes.
Installed the diode on the master solenoid to protect the master switch from current spikes.
Ran the primary alternator field lead through the firewall and connected it to the primary voltage regulator. Ran the AC compressor clutch wire through the firewall penetration. Labeled all wires.
