Connected engine sensors to shielded cables for routing to G3X inputs.
Soldered the sensor wires to the shielded cables and sealed with heat shrink tubing. Ran the shielded cables into the conduit running across the top of the firewall along with the left side engine thermocouple wires.
Secured the conduit with 2 additional tie-wraps with mounts, and then to the engine mount on each side with cushion clamps.
Cleaned up the wire routings around the cylinder heads, and secured with waxed lacing.
