Dave's RV-10 Build Log
Date:  5-1-2019
Number of Hours:  7.00
Brief Description:  Glare Shield Cover Sides, EGT/CHT Wiring
Trimmed the glare shield cover material at both sides to fit the glare shield where it attaches to the cabin door edge.
Glued the cover to the sides of the glare shield using the contact cement. Left the under side of the glare shield cover hanging as it will need to be trimmed after the panel is installed.
Installed a piece of flexible conduit across the top of the firewall to allow routing of the CHT and EGT wires from the left side of the engine to the right side, as well as to route the wires from the engine sensors mounted to the firewall and other sensors at the back of the engine. Cut slots into the conduit above the sensors and then used a soldering iron to smooth the cuts to prevent damage to the wires.
