Brief Description: Began Install of Glare Shield Cover; EGT/CHT Wire
Started installation of the "leather" glare shield cover purchased from South Florida Sport Aviation.
Removed the brace between the cabin top and the sub-panel.
Trimmed the cover at the front/windshield side to fit the seam along the back/panel edge of the glare shield.
Glued the rubber strip along the glare shield edge using Loctite Ultra Gel Control super glue.
Glued the center of the cover to the glare shield, centering the cover slit for the brace over the slot in the glare shield for the brace. Used 3M Neoprene High Performance Contact Adhesive 1357 which is a commercial adhesive that requires use of breathing mask to protect from the organic fumes.
Left the cover to set after gluing the center and began work on installing the wiring for the EGT and CHT probes.
Installed cushion clamps to a few of the rocker cover screws to route the wire. Began connecting the thermocouple wire to the EGT & CHT thermocouples.
