Completed installation of the conduit across the top of the firewall, held in place with cable tie downs secured with pulled rivets and adhesive. Pulled the EGT & CHT thermocouple wires from the left side cylinders through the conduit to the right side firewall penetration.
Routed all of the EGT & CHT thermocouple wires through the right side firewall penetration into the cabin, through the sub-panel hole bushing installed for this purpose. Also included the wires for the other engine sensors (Oil Press, Oil Temp, Fuel Press, Manifold Press,
Installed the AC Compressor relay to the sub-panel.
Tested the flat black textured paint on a piece of pipe to confirm it is acceptable before applying it to the cabin top brace.
