Installed panel ground wires into the 2 ground blocks with female pins.
Started to work on the ground wires and realized I needed a different crimping tool for the provided pins. Had to take time out to go to my shop and retreive the correct crimper (used previously for molex connectors)
Installed 2 black #22 ground wires in each pin. Larger wires were installed into individual pins. Recorded the wire numbers with each pin number that they were inserted into.
Will need to add additional ground wires to the blocks in the aircraft using the wiring already installed in the airplane.
Inserted the labels into the 3 master lights (Master Caution, Master Warn, CO Alarm/Reset). Determined the pin-out connections for these push button lights. Assembled the lights and mounted them into the panel. Checked the LED operation with a 12 volt power supply.
Updated the wiring diagrams for minor as-built changes. Also added an additional page of notes that show the back side of the switches and panel caution/warn/CO lights/switches as well as adding tables for ground wire pins.
