Dave's RV-10 Build Log
Date:  3-28-2019
Number of Hours:  6.75
Brief Description:  PFD-1 & MFD Wiring
Completed PFD-1 Connectors wiring except for drain wires on P4102 connector. Need screws/lock washers/washers for drain wire connections to back shell to complete. Ordered hardware for this from Aircraft Spruce.
Cut wires for MFD and placed on wiring board. Started removing insulation on shielded cables for MFD connector.
Magnifying lamp purchased yesterday makes pin crimping and connector assembly much easier.
Included config module in P4102 backshell.
