Dave's RV-10 Build Log
Date:  3-25-2019
Number of Hours:  4.25
Brief Description:  Determine CAN Bus Order & Document
In order to complete the wiring diagrams, I needed to determine the CAN Bus interconnections order between the various LRUs.
Per recommendation from AEA class, decided the bus will be terminated at the GSA 28 roll servo in the wing, and at the GSU 25 ADAHRS on the sub-panel. Revised the CAN Bus diagram to show the correct relative placement of all the LRUs in the aircraft. Then determined the best connection path between the LRUs which determined the connection order.
Documented this connection order on the wiring diagrams by labeling each of the CAN bus connections on the diagram. In doing this, found a few mistakes in the diagrams which were corrected. Updated and printed a new set of wiring diagrams.
