Dave's RV-10 Build Log
RV-10
Avionics Relay, Switches, Measured Sub-Panel
Determined location for the Avionics Power Relay below the center circuit breakers. Drilled a mounting hole in the panel for this relay.
Measured the wire routes from the main bundle to each of the devices mounted on the sub-panel and sketched up a wire routing diagram for these.
Installed the switches in the panel.
RV-10 Home
3188
Air Conditioner
757
Finishing Kit
115
568
273
545
Phase 1
Wings & Fuselage
