Dave's RV-10 Build Log
Date:  3-20-2019
Number of Hours:  1.50
Brief Description:  Sketched Wire Bundle Routing Diagream with Distanc
Sketched up the panel wiring harness branches, with the main cable bundle running along the bottom of the sub-panel. Will install cable ties along the bottom of the sub-panel to hole this main bundle. [Will likely use either nylon anchor blocks with tie-wraps; or perhaps Adel clamps.
The sketched wire routing diagram shows each LRU/switch/device on the panel in relation to each other along the main wiring bundle. Measured distances from each LRU, switch, or other panel device and the main cable bundle, adding 4 inches in most cases for service loops. Then measured the points along the main cable bundle where wiring for each device will enter/exit the main cable bundle. These measurements were added to the sketch and will be used to fabricate the panel wiring harness on the table for ease of assembly.
