Took panel sections to shop to enlarge some holes that are too small.
Used step drill to enlarge breaker holes for the Avionics breaker & Standby Alternator Also enlarged holes for the 3 potentiometers for control of EFIS, Annunciator, and Overhead light levels. Added a small notch for the two Seat Heater switches so that they now fit their holes in the panel Confirmed that the hole for the A/C Fan Speed switch is the correct size.
Checked that the ProSeal on the firewall penetrations installed on Saturday March 9 have cured.
Sanded the center console first with red Scotch Brite pad, then with whiite Scotch Brite pad to clean up minor imperfections in the prior clear coats. Sprayed another coat of Rustoleum Satin Clear Enamel onto the center console.
