Started installation of the center panel circuit breakers. Determined that I don't have the right ring terminal size to connect the smaller size breakers and bus bar using #10 AWG wire. (The ring terminals I have for 10-12 AWG have too large a ring for the smaller breaker screws.)
Talked to Jason Smith of Aerotronics regarding typical installation methods and connectors. Based on his advice, I determined the proper sizes for FastOn terminals to use for connection of the panel switches and ordered these along with the required ring terminals from Aircraft Spruce.
[Stopped work for a long 4 hour lunch with the Eldridges]
