Dave's RV-10 Build Log
Date: 3-8-2019
Number of Hours: 5.25
Brief Description: Installed & Wired Shunts, Wired Voltage Reg.
Installed sensor wiring between current shunts (for battery current and primary alternator current) and fuse block and from fuseblock. Soldered all sensor wires to the fuse block and covered with heat shrink tubing. Coiled the wires that will run to the GEA 24 for future connection. Connected the sensor wires to the shunts with crimped ring terminals.
Attached the both current shunts and the fuse block to the left top of the sub-panel in the location drilled for them yesterday.
Measured, cut wires, and installed them to both voltage regulators for the sense line, field power line, and ground line. Coiled the wires for future connection to the field power switches, circuit breakers, and ground blocks.
Removed the panel from the plane. Packed up the panel, wire, screws, and tools and took them home in order to begin wiring the panel on the dining room table at home next week.
