Installed the IBBS to the middle panel tray using K1000-6 nut plates. Shifted the IBBS location and rotated it so that the fuse is facing forward and therefore accessible.
Enlarged the firewall hole on the right side to accomodate the installation of the Van's RV-14 firewall penetration fitting.
Drilled a new hole at the top center of the firewall, approx. 2 inches to the right of the brace rivets and 3 inches down from the glare shield/top skin. Enlarged the hole to use a Van's RV-14 firewall penetration fitting in this location as well.
Unpacked, inventoried, and stored the screws and nut plates received with the Aircraft Spruce order. Utilized a new tray and re-arranged a couple of my other trays so that I now have a tray with just flat head screws, one with just round head screws, and one with washer head screws.
