Dave's RV-10 Build Log
Date: 2-26-2019
Number of Hours: 7.75
Brief Description: Mounting Voltage Regulators, GSU 25, CO Detector
Reviewed the LRU mounting locations using the GDU 465 (MFD) to check for connector spacing and interferences. Revised 2 of the LRU locations to allow better clearances for improved access to connectors.
Mounted both voltage regulators to the sub-panel using AN4-4 bolts, washers, and nylon lock nuts per the B&C instructions. Used 4 bolts per voltage regulator. Mounted the main regulator on the left side for easiest wiring run to the alternator and the standby regulator on the right side for easy access to the standby alternator.
Mounted the GSU 25 (AHRS) unit to the sub-panel in the center, below the approximate location of the G5 for ease of tubing runs. Mounted it with AN3-12 bolts, washers, and nylon lock nuts. Installed the tubing T for the static and pitot tubes and an L for the AOA tube prior to fastening the GSU 25 to the sub-panel.
Installed the CO detector to the side of the center tray, using screws, washers, and nylon lock nuts. Removed the CO detector for protected storage.
Began mounting of the GTR 20 Comm radio to the left side tray. Installed #6 nut plates for each of the 6 mounting screws.
